I have to deploy ASM for Exchange 2016 on F5 VE 12.1.2. The official iApp template for Exchange 2016 have only LTM,APM and AFM, but not ASM. Can someone advise on how i go about deploying ASM?
Hi Jose,
ASM policies are not deployable via iApp. When you create an ASM policy you will have a choice to use an Application-Ready Template.
Depending on which version of BIG-IP you are running you may not have the latest templates, however F5 provides latest versions of several templates on DevCentral here (Exchange template is there):
Hope this helps,
Sam
