Hello All,
I am searching for - How to check and ensure that specific Virtual Server (VIP) is enabled with ASM. i.e. How to identify If ASM is configured for specific Virtual Server.
Hello All,
What version are you running?
You could check whether a specific virtual has one or more ASM policies attached to it using the iControl REST interface. Use both commands below:
curl -sk -u “admin:XXXXXX” -X GET “[https://localhost/mgmt/tm/asm/policies?\](https://localhost/mgmt/tm/asm/policies?\)$filter=virtualServers%20eq%20/Common/vs_app1&\$select=name” | jq .
curl -sk -u “admin:XXXXXX” -X GET “[https://localhost/mgmt/tm/asm/policies?\](https://localhost/mgmt/tm/asm/policies?\)$filter=manualVirtualServers%20eq%20/Common/vs_app1&\$select=name” | jq .
Just change “/Common/vs_app1” for the virtual server name which you want to check for …
The first command works when the virtual server has a single ASM policy attached to it. The second command works when the virtual server has multiple ASM policies attached to it (e.g: using LTM policies).
If there are any ASM policy attached to the virtual server you should see in the output of either commands …
