I want to make sure if I’m understanding well Latency-based options in ASM.
There is Suspicious Criteria, IP Detection Criteria and URL Detection Criteria.
ASM will check for these three options and the following is the possible cases:
1. Suspicious Criteria result is positive then check for IP Detection Criteria if it is positive then it considered the request as DoS.
2.Suspicious Criteria result is positive then check for IP Detection Criteria if it is negative then it check for URL Detection if it is positive then it will considered the request as DoS.
3.Suspicious Criteria result is positive then check for IP Detection Criteria if it is negative then it check for URL Detection if it is negative then it will permit the request and not alert as DoS.
- Latency-base always check for Suspicious Criteria first.
- If one of “Suspicious Criteria” detected and not select any of “Prevention Policy” options ASM just alert and not block any request.
