I’m working on an asm policy to filter only /admin/* webpages. I want that users access the whole site except admin section.
The Big-IP version is 11.5.5.
I know how to proceed with iRule but I would like to use asm instead. In application Security=>URLs=>Disallowed URLs, I can add a forbidden url but only explicite URL (ex: /admin/myadminpage.php). When I add a wildcard (ex: /admin/* ), nothing is filtered and I can access the admin section, except if I enter “https://www.mysite.com/admin/*”. In this particular case , the wildcard is considered as a real string and not as “0 or x occurences”
Is there a way to forbid a whole path with ASM? For exemple /admin* or /admin/* ? I have also tried with 12.1.3 version but it’s the same behaviour.
Ok. I was expecting your answer. I don’t understand why this option is not provide by ASM. It’s very useful to block a specific tree view (more than blocking one particular page). My objective was to limit the number of iRules we use. But not this time
For now, as workaround, we use an iRule to filter access to admin pages and raise an ASM event. If users come from the internet and not intranet, admin pages are blocking.
Here is an example :
set httpuri [string tolower [URI::decode [HTTP::uri]]]
set httpuri [string trimleft $httpuri /]
set httpuri /$httpuri
set blockurl 0
if { ( $httpuri starts_with "/admin" )} {
if { [class match [IP::client_addr] equals INTRANET_POOL_IP ] } {
log local0. "MyApp - Access granted from [IP::client_addr] on [HTTP::host][HTTP::uri]"
set blockurl 1
log local0. "MyApp - Forbidden access from [IP::client_addr] on [HTTP::host][HTTP::uri]"
when ASM_REQUEST_DONE {
if { $blockurl } {
set x []
lappend x "Requested URL" "\[HTTPS\][URI::decode [HTTP::uri]]" "Detection Cause" "Disallowed URL"
ASM::raise VIOLATION_ILLEGAL_URL $x
We have an ASM policy with a custom violation defined (with option Trigger ASM iRule Events defined enabled in Advanced Policy Properties). We use that for :
blocking evasion techniques (directory traversal and co)
logging purpose
user information
This is the only way we found to block admin pages with ASM.
