ASM detection
how do i prevent to detect the web server operating system and platform ?
you can use an irule to remove unwanted header:
when HTTP_RESPONSE {
    Remove all instances of the Server header
   HTTP::header remove Server
    Remove all headers starting with x-
   foreach header_name [HTTP::header names] {
      if {[string match -nocase x-* $header_name]}{
         HTTP::header remove $header_name
In all case you will need to know what’s header you want to remove, Once you know what it is they’re looking for you could then obfuscate those header or removes it as above…
Regards
