Policy_Export.xml:
true
If the case_insensitive parameter is set to ‘true’, are there any parts of the configuration that will remain to be treated as case-sensitive?
What will happen if policy has a parameter named
LOGIN.data
while policy is configured as case-insensitive? (are the exceptions configured in the parameter bypassed, or are they still valid?)
I don’t see a version so I will use the latest.
From 404 Page not found | BIG-IP Documentation :
"By default, the option Security Policy is case sensitive is selected, and the security policy treats file types, URLs, and parameters as case-sensitive. "
So creating the policy as case insensitive, it follows that all file types, URLS, and parameters are now case-insensitive. Elements will stored as lowercase. (from menu help)
I am not sure I understand your specific question, but here is an example case insensitivity setting
GET /index.php?UPDOWN=ROLLER HTTP/1.1
GET /index.php?UPdown=ROLLer HTTP/1.1
Both gather under
Illegal parameter:: Parameter: updown on [HTTP] /index.php (notice the lower case for parameter)
Remember, this case-insensitivity can only be selected at creation of the policy.
Both gather under
Thanks for the explanation, Richard. Actually the reason for asking is that I was migrating case-sensitive policies to case-insensitive. Apart from minor issue, I got this change executed successfully. Case-sensitivity setting can be modified in existing policies, it’s just not very straight-forward to do so
