asm capabilities encoded request
Hi
i m doing Xss attack to the ASM with
Hi Zafer,
ASM doesn’t currently provide an option to base64 decode request components. But most web servers won’t do this either so it’s not a problem. If the web application does base64 decode whatever request component you’re putting the base64 encoded attack string in, then you’d have a potential issue.
What kind of app are you testing?
Aaron
Hi hoolio
the customer use apache tomcat.
We tested several attack methods to the ASM and i can’t find how to block encoded request based on hex and base64
regards
zafer
