Hello,
We have faced with a problem, when Brure Force Protection feature inserts the script to response header. I have pasted the script below. The fact is that script is inserted for each application resource URL and break some of its functions. From the configuration of Brute Force Protection, we have only one login page with Username and IP Addres protection and Alarm and CAPTCHA mitigation. Additionaly we have Distributed Brute Force Protection being configured. for Alarm and CAPTCHA mitigation. No Client Side Integrity Bypass Mitigation and CAPTCHA Bypass Mitigation.
Any ideas how to switch of the script insert and move on with simple User login attempts tracking only?
-----the script-----
<script type=“text/javascript”>
(function(){
window.PXtt=!!window.PXtt;try{(function(){(function(){})();var b=81;try{var ba,da,ma=c(71)?0:1;for(var pa=(c(608),0);pa<da;++pa)ma+=(c(854),3);ba=ma;window.Pa===ba&&(window.Pa=++ba)}catch(a){window.Pa=ba}var e=!0;function f(a,d){a+=d;return a.toString(36)}function sa(a){var d=42;a&&(document[p(d,160,147,157,147,140,147,150,147,158,163,125,158,139,158,143)]&&document[p(d,160,147,157,147,140,147,150,147,158,163,125,158,139,158,143)]!==f(68616527624,d)||(e=!1));return e}
function p(a){var d=arguments.length,g=[];for(var h=1;h<d;++h)g.push(arguments[h]-a);return String.fromCharCode.apply(String,g)}function va(){}sa(window[va[f(1086773,b)]]===va);sa(typeof ie9rgb4!==p(b,183,198,191,180,197,186,192,191));sa(RegExp(“\x3c”)[f(1372124,b)](function(){return"\x3c"})&!RegExp(f(42808,b))[f(1372124,b)](function(){return"‘x3’+‘d’;“}));
var wa=window[t(b,178,197,197,178,180,185,150,199,182,191,197)]||RegExp(t(b,190,192,179,186,205,178,191,181,195,192,186,181),f(-63,b))[t(b,197,182,196,197)](window[”\x6e\x61vi\x67a\x74\x6f\x72"][“\x75\x73e\x72A\x67\x65\x6et”]),xa=+new Date+(c(66)?883940:6E5),ya,Aa,Ca,Da=window[p(b,196,182,197,165,186,190,182,192,198,197)],Ga=wa?c(280)?41740:3E4:c(40)?5090:6E3;
document[p(b,178,181,181,150,199,182,191,197,157,186,196,197,182,191,182,195)]&&document[p(b,178,181,181,150,199,182,191,197,157,186,196,197,182,191,182,195)](p(b,199,186,196,186,179,186,189,186,197,202,180,185,178,191,184,182),function(a){var d=53;document[t(d,171,158,168,158,151,158,161,158,169,174,136,169,150,169,154)]&&(document[t(d,171,158,168,158,151,158,161,158,169,174,136,169,150,169,154)]===f(1058781930,d)&&a[p(d,158,168,137,167,170,168,169,154,153)]?Ca=!0:document[t(d,171,158,168,158,151,
158,161,158,169,174,136,169,150,169,154)]===f(68616527613,d)&&(ya=+new Date,Ca=!1,z()))});function z(){if(!document[t(86,199,203,187,200,207,169,187,194,187,185,202,197,200)])return!0;var a=+new Date;if(a>xa&&(c(971)?357226:6E5)>a-ya)return sa(!1);var d=sa(Aa&&!Ca&&ya+Ga<a);ya=a;Aa||(Aa=!0,Da(function(){Aa=!1},c(151)?0:1));return d}z();var Ia=[c(518)?10764609:17795081,c(13)?27611931586:2147483647,c(291)?1738068546:1558153217];
function t(a){var d=arguments.length,g=[];for(var h=1;h<d;h++)g[h-1]=arguments[h]-a;return String.fromCharCode.apply(String,g)}function Ja(a){var d=75;a=typeof a===f(1743045601,d)?a:a[t(d,191,186,158,191,189,180,185,178)](c(919)?20:36);var g=window[a];if(!g||!g[t(d,191,186,158,191,189,180,185,178)])return;var h=“”+g;window[a]=function(k,l){Aa=!1;return g(k,l)};window[a][p(d,191,186,158,191,189,180,185,178)]=function(){return h}}for(var Ka=(c(361),0);Ka<Ia[f(1294399124,b)];++Ka)Ja(Ia[Ka]);
sa(!1!==window[t(b,161,169,197,197)]);window.Ea=window.Ea||{};window.Ea.Tb=“0872e5a9b7194000fb04471cd1841afc6bba0c62c7db56573b9c11b63d25ddd1c1a44f037a57d1166fd77c497d0714ca9ba53a24cbbac8c76c2c3d741c020071564ba89bfedd964f”;function B(a){var d=+new Date;if(!document[t(20,133,137,121,134,141,103,121,128,121,119,136,131,134,85,128,128)]||d>xa&&(c(136)?480406:6E5)>d-ya)var g=sa(!1);else g=sa(Aa&&!Ca&&ya+Ga<d),ya=d,Aa||(Aa=!0,Da(function(){Aa=!1},c(580)?0:1));return!(arguments[a]^g)}function c(a){return 33>a}(function La(a){return a?0:La(a)*La(a)})(!0);})();}catch(x){}finally{ie9rgb4=void(0);};function ie9rgb4(a,b){return a>>b>>0};
</script>
