ASM and TCP based applications
Hello, I am not an F5 expert, but am asking on behalf of a customer. I am trying to find the following:
Can ASM be leveraged to inspect application traffic when the application is using a TCP (not HTTP) based access policy? If so, is this out of the box or is there special configuration required? The customer is using Big-IP using F5 for reverse proxy and SSL offload.
Any help would (and links) would be greatly appreciated.
Thanks, Marcus
Hello,
ASM is a Web application firewall and is dedicated to the protection of web apps.
You can use the ASM license to protect smtp and ftp services.
If you have a custom TCP app, you have better to go with LTM, irules and IP Intelligence (ip reputation db)
You can find info on devcebtral and askf5.f5.com
Hello,
Thanks a lot for the quick response. In this case it actually is a web app using websockets, which require a TCP based access policy. I am assuming this does not change your answer? Please confirm, then I’ll mark your answer. Thanks! Marcus
The upcoming ASM v12.1 supports WebSocket applications. The standard TCP profile must be used on the virtual server, and then you add a WebSocket profile. Automatic configuration of WebSocket URLs is also configurable.
Hi, Websocket is currently supported using LTM only. As Erik mentioned, you need to wait for the 12.1.0 to be released
Many thanks!
Many thanks!
we are using v13.0 How do we configure the policy? And what is required from LTM side?
