Is there a way to represent the hex 0a in the target of a STREAM::expression? Everything I try causes the literal “0a” or “\n” to be inserted instead of the representation of LF.
STREAM::expression {@\x0d@\x0a@}
Result of replacement is “\x0a” (5c 78 30 61)
STREAM::expression {@\x0d@\n@}
STREAM::expression {@\r@\n@}
Both of these cause the replacement to be the literal “\n” (5c 6e). Is seems that the search operations handles regex/hex just fine, but the replacement chokes on anything other than ASCII.
Hi Walther,
the fix is rather simple. Don’t use
Curly-Braces
to allow the
\n
to become substituted…
STREAM::expression "@\n@\n\n\n@"
Cheers, Kai
In case someone else needs to perform a substitution on something not as simple as “\r” or “\n”… I just came up with this explanation…
With some guidance from DevCentral - An F5 Technical Community and some confusion over when to use decimal or hex, I came up with the following solution
when CLIENT_ACCEPTED {
Store hex 0a (Decimal of 10) as a binary format
set replacement [binary format c* {10}]
STREAM::expression @\r@$replacement@
STREAM::enable
