I’ve been battling with this thing for a couple weeks and cannot figure it out. Here is my declaration for the PATCH Method allowing us to create one-off VIrtual Servers inside of our F5.
"class": "AS3",
"action": "patch",
"patchBody": [
"op": "add",
"path": "{{path}}",
"value": {
"class": "Application",
"{{application_name}}": {
"class": "Service_HTTPS",
"virtualAddresses": {{virtual_address::array}},
"pool": "{{pool_name}}",
"serverTLS": "{{client_profile_name}}",
"profileHTTP": "basic",
"layer4": "tcp",
"profileTCP": "normal",
"enable": true,
"snat": "auto"
"{{pool_name}}": {
"class": "Pool",
"monitors": [
"tcp"
"members": [{
"servicePort": {{pool_port::integer}},
"serverAddresses": {{server_addresses::array}},
"loadBalancingMode": "round-robin"
"{{client_profile_name}}": {
"class": "TLS_Server",
"certificates": [{
"certificate": "{{webcert}}"
"{{webcert}}": {
"class": "Certificate",
"remark": "in practice we recommend using a passphrase",
"certificate": "{{cert_metadata}}",
"privateKey": "{{key_metadata}}",
Unfortunately we are running into this error here and i’m not understanding why. Any help is appreciated. Thank you.
ERROR: Failed to render template. Details:
Failed to get data from /mgmt/shared/fast/render?userAgent=FASTGUI/NA: 400 Bad Request
{“code”:400,“message”:“request failed with null exception”,“originalRequestBody”:"{\“code\”:400,\“message\”:\"Error: failed to render template: patch2/patch2\\nSyntaxError: Unexpected token , in JSON at position 811\\n at JSON.parse (<anonymous>)\\n at /var/config/rest/iapps/f5-appsvcs-templates/nodejs/fastWorker.js:1601:23\\n at /var/config/rest/iapps/f5-appsvcs-templates/node_modules/core-js/modules/es.promise.js:118:22\\n at flush (/var/config/rest/iapps/f5-appsvcs-templates/node_modules/core-js/internals/microtask.js:27:9)\\n at tryCatcher (/usr/share/rest/node/node_modules/bluebird/js/release/util.js:16:23)\\n at Promise._settlePromiseFromHandler (/usr/share/rest/node/node_modules/bluebird/js/release/promise.js:512:31)\\n at Promise._settlePromise (/usr/share/rest/node/node_modules/bluebird/js/release/promise.js:569:18)\\n at Promise._settlePromiseCtx (/usr/share/rest/node/node_modules/bluebird/js/release/promise.js:606:10)\\n at Async._drainQueue (/usr/share/rest/node/node_modules/bluebird/js/release/async.js:138:12)\\n at Async._drainQueues (/usr/share/rest/node/node_modules/bluebird/js/release/async.js:143:10)\\n at Immediate.Async.drainQueues (/usr/share/rest/node/node_modules/bluebird/js/release/async.js:17:14)\\n at runCallback (timers.js:794:20)\\n at tryOnImmediate (timers.js:752:5)\\n at processImmediate [as _immediateCallback] (timers.js:729:5)\\n at /var/config/rest/iapps/f5-appsvcs-templates/nodejs/fastWorker.js:1628:35\\n at /var/config/rest/iapps/f5-appsvcs-templates/node_modules/core-js/modules/es.promise.js:118:22\\n at flush (/var/config/rest/iapps/f5-appsvcs-templates/node_modules/core-js/internals/microtask.js:27:9)\\n at tryCatcher (/usr/share/rest/node/node_modules/bluebird/js/release/util.js:16:23)\\n at Promise._settlePromiseFromHandler (/usr/share/rest/node/node_modules/bluebird/js/release/promise.js:512:31)\\n at Promise._settlePromise (/usr/share/rest/node/node_modules/bluebird/js/release/promise.js:569:18)\\n at P
