Application Logged Out when Idle . . .
Hey friends,
I have a problem … when we access application using a server directly, it is stabil (NOT LOGGED OUT), but when accessing it using the F5 application and idle, the application back to the login menu (LOGGED OUT), but if we click on the menu quickly (INTENS), is not logged OUT. We have already setting an “indefine” idle time out in tcp profile, and we have also tried giving an idle time out of more than 5 minutes, but the application is still logged out when we accessed less than 1 minute if idle.
AnyOne Help for this case??
please try to use oneconnect profile on vs side… and test again.
What persistence mechanism applied in the VS?
Hiii Vijayyy,
When we must using persistence like a Cookie persistence, source address persistence, dest persistence affinity, SSL?
Can you give me example for using each persistence with case, problem, or case study in real environtment like case application, proxy, web or etc that need persistence?
Thx so much
