Appending iRule
I have requested to create iRule which will add appending to url, as the customer will write (http://mycompany.com ) and the application won’t work unless you write the following (http://mycompany.com/test/app.aspx )
1) I created the following irule but the pictures on the page doesn’t appear
if { not ([HTTP::uri] starts_with “/test”) } {
HTTP::uri /test/app.aspx [HTTP::uri]
2) I used redirection irule like this and it works but I don’t know if this will affect the application
if {
[HTTP::uri] equals “” or [HTTP::uri] equals “/” } {
HTTP::redirect http://mycompany.com/test/app.aspx }}
I would like if someone help me in No.1 to make work.
For the first iRule, let’s say your incoming URI is “/foobar”. You are resetting the URI to the “/test/app.aspx /foobar”. I’m assuming that isn’t what you want to do. If you just want to change the URI to /test/app.aspx" then leave out your trailing [HTTP::uri] from the assignment.
-Joe
You mean to remove [HTTP::uri] and make like this:
But this gives the same results as the pictures didn’t appear.
If you just want to rewrite requests to the root document (path equals /), you could use this:
     Check if path is /
    if {[HTTP::path] eq "/"}{
        Rewrite path to /test/app.aspx
       HTTP::path "/test/app.aspx"
If you want to prepend a string to all URIs if it’s not there already, you can use a rule like this:
     Check if path doesn't already start with /test/
    if { not ([HTTP::path] starts_with "/test/")}{
        Rewrite path by prepending "/test/"
       HTTP::path "/test/[HTTP::path]"
Note that if you don’t care about inspecting the query string it should be more efficient to modify just the path using HTTP::path.
Aaron
All,
I have an append/redirect question.
Right now I am doing a straight redirect based on two different paths, but now my users want to add arguments to the paths how can I do this? Below is the current rule and an example of the url the users are trying to use.
if { [HTTP::uri] equals “/dev” } {
log local0. “Found the uri /”
HTTP::redirect “https://www.server1.com:4444/dev”
if { [HTTP::uri] equals “/test” } {
HTTP::redirect “https://www.server1.com:4444/test”
so basically the redirection takes you to the apache server running on 4444 instead of 443, but the question is if a user hit https://www.server1.com/test/USERNAME -or- https://www.server1.com/dev/PROJECT the redirect takes them to the mainpage (since that is what the rule tells it to do), but how can I grab the PROJECT code or the USERNAME and pass that to the redirect or append it to the redirect?
Thanks,
Matt
Hi Matt,
It would help if you created a new post for your question. You can parse the fields in the path using getfield:
[getfield “/path1/path2/path3” “/” 3] returns path2
So [getfield [HTTP::path] “/” 3] for a request to /test/USERNAME would return USERNAME.
If you create a new post, can you add a few examples of what you’d like the original and modified requests to look like?
Thanks,
Aaron
