APM with NTLM SSO
Hi Team,
I have to deploy APM with NTLM SSO, anybody who have done this please share your input it’s simple or very difficult. I have come across a link on devcentral https://devcentral.f5.com/articles/leveraging-big-ip-apm-for-seamless-client-ntlm-authentication. as per this link i need irule, but in f5 sso admin guide it is very simple configuration. The steps give in f5 sso admin guide is incomplete ? do i have to follow all the steps give in DevCentral - An F5 Technical Community?
Thanks, Sachin
the first question with this is usually what do you want to exactly do? APM with NTLM SSO can mean two very different things, were one is easy and the other can require more config.
please explain what you want more extensive then APM with NTLM SSO. where are your clients, where are your servers, what user experience do you expect?
clear, so that is the “easy” variant of NTLM SSO. in principle you just have to add a SSO Credential Mapping VPE in your Policy (after your auth VPE) and add a NTLM SSO on your Access Profile (SSO / Auth Domains tab).
NTLM SSO also require variable session.logon.last.domain is defined as NT domain name
do a variable assign:
session.logon.last.domain = expr {“DOMAIN”}
Are you trying to do SSO over applications accessed over SSL VPN? If so, you need to create layered virtual server for the web application accessed.
Hi Kunjan, yes, Im trying to do SSO over applications accessed over SSL VPN.
If so, have to create a VIP matching the webapp IP address as explained in the Solution article.
Client <= via VPN tunnel => APM NA vs <--> layered VS ↔ internal webapp server
1) One http virtual for APM network access
2) One or more http layered http virtuals corresponding to the internal webapp server that requires SSO support.
