APM - Windows 10 1709 and Portal Access problem.
Hi all!
I have an APM (BIG-IP 12.1.2 Build 1.0.271 Hotfix HF1) and users with Windows 10 1709 version and IE 11.
Users login into web access (https://myapm.com/) ok, and then when users try to connect to Portal access (in this case Citrix Storefront), the page doesnt charge ever.
I have try whit other webs types and the behaviour is the same.
Anybody knows some issue whith last versions of w10 or IE11 and Portal Access?.
Thanks in advance.
"Microsoft® Windows OS
F5 Networks supports 32-bit and 64-bit versions of Windows® Vista SP2, Windows® 7 SP1, Windows® 8.1 Update, Windows® 10 running IE11, Firefox 34, or Chrome 40*. Only 32-bit browsers are supported. Microsoft Edge browser is not supported. Edge Client is not supported when Windows 10 Device Guard is enabled."
