Hello DevCentral,
How I can control that the user that is authenticated on APM can only use the webtop links and nothing else?
Thanks in advance,
M.
Hello DevCentral,
Thanks in advance,
M.
Its not possible. Through local account you can restrict to VS(Operator Access)
Are you referring to the management side of things, or users that are authenticated using APM can only see the webtop links on their webtop?
