Hello,
Has anyone found a way around the issue that a password containing unicode characters (a-umlaut, u-umlaut, etc.) is garbled and thus rejected when using NTLM WebSSO authentication in APM by back end Windows servers?
Front end authentication with a VPE containing AD Query and AD Auth work fine, just the backed SSO is broken with NTLM.
There is an RFE for it, 398134 but I can only assume that not many non-US users have not had many issues with it as it has not been fixed and is “merely” a request for enhancement …
All of our users have either a German, French or Italian keyboard thus it is quite normal to have an ü, ö or ä in there passwords. This is causing our help desk serious headaches resetting their passwords.
thanks.
Hi there,
this topic is quite some days old, but seems to match my issue as well. So I assume it might be the same root cause.
I’m also using a APM policy with SSO, but “only” with HTTP basic. A users password contains the character “§” and the F5 parses this incorrectly to the backend server (resulting in a 401). I sniffered the traffic both with SSO enabled and without.
Without SSO this character will be displayed as “\247” in Wireshark.
With SSO this character will be displayed as “\302\247” in Wireshark.
Any idea how this can be fixed within APM?
Thank you!
Ciao Stefan
So, now i have a similar issue. I am parsing the Basic Auth Header from the Request inside an iRule and set it into a session variable for APM → special characters are now garbage.
Would also like to see a solution to this.
Cheers, Rene
same problem here. could u find a solution?
i would advise you to open a support ticket for this and please report back on the response and possible bug ID.
