APM - Web Application Split Tunnel
Does anyone have any examples to create a split-tunnel environment like the Firepass?
I am trying to create the following scenario which is easy with the Firepass:
1: Split-Tunnel ACL - example: www.f5.com
2: Rewrite ACL - example: *.f5.com
3: Default Rewrite Rule - Bypass Rewrite Engine like links on devcentral.f5.com to www.gartner.com
4: Deny ACL - example: devcentral.f5.com/adminconsole
5: Allow ACL - example: devcentral.f5.com
6: Default ACL - Deny All - this will block support.f5.com but not www.gartner.com
So far the APM is a little reversed concept:
1: Default Rewrite Rule - Rewrite everything
2: Application Web Application ACL
3: Flexible L7 ACL
I am assuming I can use I-Rules REWRITE_RESPONSE_DONE but I don’t know the command to ignore the Rewrite Engine for weblinks.
1: Create a datagroup to bypass ACL = www.f5.com
Scan website for links and compare to datagroup like
if { [matchclass bypass-web-group equals “$[HTTP::host]”] }
Do not Rewrite links
2a: Create Application Web Application for all websites which needs to be rewrite - *.f5.com over 80/443
2b: Create a Datagroup which matchs the ACL on Web Appliation
3: Next level of I-rule will scan website for links and compare to the next datagroup like
if { [matchclass rewrite-web-group not equal “$[HTTP::host]”] } - Rewrite all other links - www.gartner.com
4: Create a ACL to block like devcentral.f5.com/adminconsole
5: Create a ACL to Allow website like devcentral.f5.com
6: Create a Bottom-ACL to block all websites
If we can’t control Rewrite engine, is there a way to inject around the web-links before it gets to the APM?
Hi blacksan,
I think we’ll have an updated set of docs on the APM wiki for this shortly. You might try talking with your F5 or partner SE for details in the meantime.
The titles will be:
APM Portal Host Rewrite
REWRITE::enable|disable
Aaron
