APM VPE - Group of computers
Hello,
I deployed a policy for our VPN via Edge Client. The client check several parameters on the computer and currently, to be able to connect the VPN, the user must be member of a specific Active Directory group. But, is-it possible to change that and not check if user is member of an AD group but check if the computer is member of a specific group ?
BR
there isn’t an easy way, you will have to look up your computername in LDAP, this earlier question shows how to handle that, mainly the sections at the bottom
https://devcentral.f5.com/s/question/0D51T00006i7WjL/ldap-query-for-machine-account
give it a go, if you get stuck let me know, i can give it a try also.
