APM V11.2 webtops and SSO to other APM VIPs
Hi Guys,
I’ve been attempting to configure APM to share configuration between VIPs that share like configurations.
I currently have this working between Citrix and OWA, so if a user logs in to Citrix, and then goes to OWA they don’t get reprompted for auth. However, if you go from either of those to a VIP that has a APM dynamic webtop the user gets prompted for auth.
All SSO configuration is pretty much identical (with exception to the SSO profile used).
Has anyone tried this? Has anyone done this? Any suggestions?
Regards,
*edit* Also, going between two VIPs with dynamic webtops break also.
have you tried this?
i am interested to know how you did the shared auth between two VIPs. currently i have an issue where i need a full webtop and a landing URI (portal access webtop) and APM only allows one webtop. looks like the only solution is to have two access policies and switches between them without re-auth…
thanks
Yes, how are you sharing access between the policies? Domain cookies?
