APM two-factor authentication issues.
Hello All
I have a APM used two-factor authentication ,The first is AD auth and the second is DUO auth.Have been able to used two-factor authentication.
My question is below:
When the user used the VPN and then exit the F5 edge client.
“After one hour”.The user to login the F5 edge client again.
I need the user to automatically skip AD authentication, only perform DUO authentication.
If more than one hour, The users need to perform all the two-factor authentication.
So. How to configurtion my APM ,To login again in one hour, only perform DUO authentication.?
Thanks again everyone.
This would be quite tricky as you would need to record when a user has authenticated to determine if they have previously logged in within the last hour. APM does not native way of checking if a user has previously authenticated When a user logs off, the session is terminated and APM no longer holds session variables, so the only things I can think of are: Have something on the client that can be read using a client side check. Or, use an irule to write the username and a timestamp to the session table. Based on the presence of this information you can make a decision on what AAA method to use.
