APM SSO multi domain issue
Hi, i have tried mutli domain SSO with 3 different Virtual servers and same access profile attached to all of them and it worked fine. But, when i tried mutli domain SSO with different applications under the same Virtual server, it didn’t work and this happened. when i tried to access first application it did not authenticate me after entering credentials and didn’t give an error. and when i tried to access second application after that, it gave me F5 error that : access policy evaluation is already in progress for your current session. Any help why SSO multi connect didn’t work for different application under same VS ?
How are you defining the different applications on the same VS? The access policy will run once then the session is established. Do you see the redirects for the auth?
Seth
