I currently have Kerberos single sign on configured successfully in APM. I was wondering why my Kerberos configuration is called “myconfigname”_ntlm_kerberos? Is it defaulting to NTLM in the event that Kerberos fails? If so, is there a way to set it up to use Kerberos only? Using NTLM is a STIG violation here.
Need more information.
- Was this configuration built by some iApp?
- Do you have an NTLM SSO profile defined?
- Are you talking specifically about server-side auth (SSO), vs. client-side auth (AAA)?
Yes I did make it with an iApp
I do not have an NTLM SSO profile defined
I mean server-side auth (SSO)
Thanks for the quick reply!
Then this is just a naming convention of the iApp. If there’s no NTLM SSO profile it’s not going to failover to NTLM.
Understood, thanks!
