I am using APM with Exchange 2013. Everything works except RPC over HTTP connectivity. When I run a test using Microsoft Remote Connectivity Analyzer, it states, “Not all the required authentication methods were found. Methods Found: Basic, Methods Required: NTLM”.
I used the iAPP to generate the iRules.
The APM log shows the following for RPC:
debug tmm[25768]: 01490000:7: HTTP uri: /rpc/rpcproxy.dll
debug tmm[25768]: 01490000:7: HTTP len:
debug websso.0[26355]: 014d0001:7: ctx: 0x9d9d7e8, CLIENT: TMEVT_EOF
debug websso.0[26355]: 014d0001:7: ctx: 0x9d9d7e8, CLIENT: TMEVT_SHUTDOWN_PROXY
debug tmm[25768]: 01490000:7: Matches RPC
debug tmm[25768]: 01490000:7: method: RPC_IN_DATA
debug tmm[25768]: 01490000:7: Src IP: 111.111.111.111
debug tmm[25768]: 01490000:7: User-Agent: MSRPC
debug tmm[25768]: 01490000:7: HTTP uri: /rpc/rpcproxy.dll?a3e42228-fa25-40a4-b7c1-70571d7792b3@taot.com:6002
debug tmm[25768]: 01490000:7: HTTP len: 0
debug websso.0[26355]: 014d0001:7: ctx: 0x9da2f28, SERVER: TMEVT_SHUTDOWN_PEER
debug websso.0[26355]: 014d0001:7: ctx: 0x9d9d7e8, CLIENT: TMEVT_SHUTDOWN_PEER
debug websso.0[26355]: 014d0001:7: webssoContext destructor …
debug websso.0[26355]: 014d0001:7: webssoConfig destructor
debug apd[23502]: 01490000:7: modules/Authentication/Identity/ifmap_connection.cpp func: “ifmap_send_keep_alive()” line: 121 Msg: Found 0 IF-MAP connections
iRules impacting SSO and RPC:
SSO_iRule:
when ACCESS_ACL_ALLOWED
set req_uri [string tolower [HTTP::uri]]
if { $req_uri contains "/owa/auth" } {
WEBSSO::select [set foo /Common/exchange.app/exch_form_basedv2_sso]
unset req_uri
RPC iRule:
when ACCESS_ACL_ALLOWED {
set sessionid [ACCESS::session data get "session.user.sessionid"]
switch -glob -- [string tolower [HTTP::path]] {
"/microsoft-server-activesync*" {
pool /Common/exchange.app/exchange_as_pool
COMPRESS::disable
CACHE::disable
return
"/owa*" {
pool /Common/exchange.app/exchange_owa_pool
return
"/ews*" {
pool /Common/exchange.app/exchange_oa_pool
COMPRESS::disable
CACHE::disable
return
"/ecp*" {
return
"/oab*" {
persist none
return
"/rpc/rpcproxy.dll*" {
COMPRESS::disable
CACHE::disable
return
"/autodiscover*" {
pool /Common/exchange.app/exchange_ad_pool
persist none
return
default {
when HTTP_RESPONSE {
if { [string tolower [HTTP::header values "WWW-Authenticate"]] contains "negotiate"} {
ONECONNECT::reuse disable
ONECONNECT::detach disable
NTLM::disable
if {[HTTP::header exists "Transfer-Encoding"]} {
HTTP::payload rechunk
