Is there a way to organize how the list of resources are displayed within a webtop resource assign?
From what I can tell, the order is based on your resource assignments in the VPE. It seems that Portal Access resources are listed first, in the order they’re assigned (I use the
Advanced Resource Assign
), then the Webtop links in similar order, and then RDP type links in similar order.
I get that part as the default, but it would be nice to be able to take all of the resources and sort them alphabetically or have some other tag to sort them by?
If there is no better way, I was thinking of adding something to the object description and generating some web code to sort based on the object description but I really don’t want to do something like that if it is not necessary.
I agree. I would like to see there be a way to organize them, though as far as I have seen, there’s not a way. For now, I just reorganize the items in my Advanced Resource Assign to reorganize them as best as I can.
was asked a while ago and there was no way to do this. unsure if it would get better with version 12. with some googling you might be able to find to old question.
