Hi, is it possible to assign resource to users based radius attribute like nested group in active directory. for exm. i have two user group that are technical and sales in radius. if a user from technical group then I will provide to the user a network resource, if user from sales group then I will provide to the user a portal access resource. Thanks,
If the Radius auth is returning this group information to you, it should be available in session variables. I don’t remember which session variable this would be in, but you could essentially add an Empty agent in the visual policy, evaluate on the value of this session variable in the branch rules, and then assign different resources to different branches. Something like this:
expr { [mcget {session.radius.last.attr.groupid}] equals "sales" }
Hi Kevin, Thanks for your response. I created the policy as the below screenshot but it did not work. I also used an empty agent nothing changed.Are you sure that the ..attr.groupid is correct value to extract radius group id. Have you tested the value before? Many thanks,
Are you sure that the ..attr.groupid is correct value to extract radius group id?
Absolutely not. At the time of writing the last post I used this as an example for syntax only. I’ve had a little more time to dig into it though, and I’d direct you to this document:
that states “session.RADIUS.last.attr.$attr_name” is the set of variables that you’d expect to see if RADIUS completed successfully. The “$attr_name” part is dynamic, so I’d suggest you either:
Perform a successful RADIUS auth first without doing any evaluation on its return values so that you can run an access policy report and see what is actually being returned. The report should show you what values are extracted into separate session variables and what those variables are named.
Run a network capture and see what the RADIUS server is sending back in its response packets (WireShark is probably best for this given its ability to filter and display the protocol data). I would do this as a troubleshooting step if the above doesn’t produce any session variables.
Hi Kevin, May I need to send the radius group information of users to server to authentication it because I only send username and password to server by f5. I need to create a box to send group information in the logon page? Thanks,
I’m not sure I understand the question. I assumed from your first post that you wanted to perform a RADIUS auth based on user credentials, and would have the RADIUS server configured to send user attributes back in its response. If that’s still the case, then you need to look at what those attributes are before you can configure anything in the APM visual policy to allow access to different resources based on them. I’d recommend creating a visual policy that does a simple allow at the end of the RADIUS auth agent. Then once you have a successful auth, run an access policy report in the GUI and see what session variables are available from the RADIUS server’s response.
So for example, let’s say RADIUS returns a “groupid” value, which is assigned to the session.radius.last.attr.groupid session variable (again, arbitrary for the sake of this example). In the visual policy, directly after the RADIUS auth, place an Empty agent (it’s actually called that). Open it up and go to the branch rules tab. Create TWO branches (it’ll 3 branches including the fallback branch). For the first branch, enter something like the following:
For the second branch, enter something like the following:
expr { [mcget {session.radius.last.attr.groupid}] equals "tech" }
In the visual policy, place the appropriate full resource assignment after each respective branch of the Empty agent.
Hi Kevin, the server returns “AVP: l=13 t=Class(25): 4f553d616f62746f74703b” response code. I coverted the" 4f553d616f62746f74703b" and I see that the value correspond to the radius group name that is aobtotp.Then I changed the expression as expr {[mcget {session.radius.last.attr.class}] == “aobtotp” but it did not work.I think my policy is wrong or may apm does not work properly. I created the policy tree as below.
Can you elaborate on how you “I converted the 4f553d616f62746f74703b” value? After a test, run an access policy report in the GUI and see what RADIUS session variables are available. Do you see “4f553d616f62746f74703b” or do you see “aobtotp”?
Hi Kevin, I used the wireshark by the right click on the “4f553d616f62746f74703b” and copy → value finally pasted the copied value and I get the aobtotp radius group id. I run access policy report after perform a test and see the same values that are "Session variable ‘session.radius.last.attr.class’ set to ‘4f553d616f62746f74703b’ . what is your suggestion for the latest status. Do I need open a ticket for the issue?
Okay, so “4f553d616f62746f74703b” is what is returned in the RADIUS auth, and what populates the session.radius.last.attr.class session variable. I still don’t get how you derive the aobtotp radius group id from that value.
Okay, this was a fun one. You would need to convert this HEX value to ASCII, which is what WireShark is doing. So in an iRule attached to the VIP, insert the following:
when ACCESS_POLICY_AGENT_EVENT {
if { [ACCESS::session data get session.radius.last.attr.class] ne "" } {
set bin [ACCESS::session data get session.radius.last.attr.class]
convert this HEX string for binary format input
if { [catch {
set ascii ""
for { set i 0 } { $i < [string length $bin] } { incr i 2 } {
append ascii "0x[string range $bin $i [expr $i + 1]] "
binary format HEX data to ascii and add to an APM session variable
[ACCESS::session data set session.radius.last.attr.class.decoded [binary format c* $ascii]
} err] } {
log local0. "error = $err"
The ACCESS_POLICY_AGENT_EVENT event is triggered from an iRule event agent inserted into the visual policy (after the RADIUS auth) agent. If the session.radius.last.attr.class value is populated from a good auth:
The HEX string will be formatted for binary conversion. So “4f553d616f62746f74703b” will become:
"0x4f 0x55 0x3d 0x61 0x6f 0x62 0x74 0x6f 0x74 0x70 0x3b" -
The new value will then be converted to ASCII and shoved into a new session variable: session.radius.last.attr.class.decoded, which should become:
OU=aobtotp; -
From there you can evaluate this value in your access policy and beyond.
There is no dollar sign before the err variable in the catch statement. Please take a closer look at my previous iRule sample. Notice the $err value in the log local0. statement, and the err variable in the catch statement immediately before that line.
Hi Kevin, Thank you for your all answers. I edited the $err value and I run load sys conf command but get the use curly error message . I also get the expected integer but got “0x0x” error message. I could not sure the second error message is due to the curl error. I also used “0x4f 0x55 0x3d 0x61 0x6f 0x62 0x74 0x6f 0x74 0x70 0x3b” , “4f553d616f62746f74703b” values on the irule event in policy but the same expected integer error message. Thanks again,
Can you show your current iRule?
Hi Kevin, My current irule ;
when ACCESS_POLICY_AGENT_EVENT { if { [ACCESS::session data get session.radius.last.attr.class] ne “” } { set bin [ACCESS::session data get session.radius.last.attr.class]
if { [catch {
set ascii ""
[ACCESS::session data set session.radius.last.attr.class.decoded [binary format c* $ascii]]
} err ] } {
Thanks,
Let’s throw some additional logging in there:
log local0. "bin = $bin"
if { [catch {
set ascii ""
log local0. "ascii = $ascii"
log local0. "decoded = [binary format c* $ascii]"
} err] } {
Please test and report the results.
Hi Kevin, I tested the rule and got the below log messages.
info tmm5[13204]: Rule /Common/radius_rule : bin = 0x4f553d616f62746f74703b info tmm5[13204]: Rule /Common/radius_rule : ascii = 0x0x 0x4f 0x55 0x3d 0x61 0x6f 0x62 0x74 0x6f 0x74 0x70 0x3b info tmm5[13204]: Rule /Common/radius_rule : error = expected integer but got “0x0x”
