the second handles LTM (mainly used as a loadbalancer)
On the first box, we have a virtual server with an APM profile linked to it. In this APM profile, we request that clients send a certificate, which gets verified through OCSP. If allowed, then the client is forwarded to one of 2 virtual servers on the second box. (Handled by an irule)
The clients which will use this infrastructure can’t handle redirects, so I have added an extra irule which puts this configuration into clientless mode. (Adding header clientless-mode)
However, when I try to access one of the 2 possibilities, I get a 404 page. Refreshing it (which also sends cookies I got in the first 404 reply) shows the page I request. Is there a way that I get to the page immediately without refreshing?
You could try to add some logging in your iRule just to verify where things are going and what the URI is. Then from the CLI (using PuTTY or some other SSH client and command
tail -f /var/log/ltm
), or the log section of the F5 admin site, and see what gets logged to verify you’re getting the right routing.
log local0. "URI: [HTTP::uri]"
if { [HTTP::uri] starts_with "/xxx/" } {
log local0. " Routing to IP_address_VS2"
node IP_address_VS2 80
log local0. " Routing to IP_address_VS3"
node IP_address_VS3 80
you could also loop and log the cookies that exists for the request if those matter on the back end.
log local0. " Cookies:"
foreach cookie [HTTP::cookie names] {
Log the cookie name and value
log local0. " $cookie: '[HTTP::cookie value $cookie]'"
personally i don’t see why virtual server routing would be the issue? you go to vs2 or vs3 and one causes the first time a 404, but not afterwards.
i think the only cause of the 404 can be the backend server. so determine if this is case with tcpdump and check if there is a difference on the first and the second request.
a nice test would also be to directly access the backend server, does it work fine on the first try then? check the difference between that request and the one through the BIG-IP.
Simultaneously, I created a support case at F5 for this problem. During the investigation, I have found something interesting. VS1 has snat activated. Using the SNAT address, and added logging in the irule I mentioned above, I checked the network captures and found this:
the first time I make a request, I see the GET being delivered to VS3 instead of VS2. However, in my LTM logs, the irule I mentioned above logs that VS2 will be used. When I do a refresh, I see the GET package now being delivered correctly to VS2. It is as if the irule isn’t executed correctly the first time, or the node command is not executed the first time the irule is called.
In the meantime, we have found a solution for this problem:
there seems to be an issue with using an apm profile together with irules which use the node or pool command. Instead, I created now a forwarding policy in LTM which takes over the role of the irule. In this policy, I defined the forwarding to VS2/VS3 based on http-uri. (2 rules were created in the policy, 1 for each VS)
Tested this with my browser and an external client. Both work ok now
