APM - Portal Access using Route Domains
Hey all,
Having a little trouble with this one and seeing if anyone can advise.
I have a BIG-IP APM on 11.6.0 HF3 ENG.
It has an external public facing interface (RD:0), an internal interface (RD:0) for authentication etc, and an internal interface (RD:1) for authenticated users.
I’m trying to setup the following…
  • External Virtual server has the APM Policy virtual server attached.
  • Client connects, executes the policy (presumably gets an “allow”) and is placed inside of RD:1. They are then provided a full webtop with two items, a full network access and a portal access (in this case used for Citrix).
  • If the client then uses the portal access for Citrix, it should look at a Virtual server on RD:1 which answers the requests and balances the request to a pool of our Citrix Web Interface servers.
The configuration I have in place, for testing, is as follows.
Virtual Server: SSL Bridging, Policy Attached, Auto-map SNAT, http profile, rewrite profiles, connectivity, VDI.
APM Policy:
  • Start
  • Login Form
  • Auth AD
  • Variable Assign (Domain for SSO)
  • SSO Creds Assignment
  • Advanced Resource Assignment (Full WebTop / Portal Access)
  • End: Allow
Portal Access: Full Patching, Match Cases, Publish WebTop, App Start URI: https:///Citrix/XenApp/ Resource item: :443/*
I have also tried %1:443/* (as per an article I saw on here).
I’ve also tried changing the app start uri to affix %1 but that just b0rks the host part up.
Interesting though, if I tell the portal access to go to one of the CWI servers directly, tcpdump shows no traffic leaving RD:1’s interface. Neither have I seen any going anywhere else, just an immediate drop.
Appreciate any and all input.
Thanks,
JD.
Try this: keep the IP in URL without route domain and in the Advanced Resource Assign, Assignment tab, select Route Domain and SNAT Selection and click the Add Item button. From the Route Domain list, select a route domain and click Save.
