APM Portal Access slow on Port 443
hi Everyone,
I am facing a slowness issue with my Portal Access configuration, when i access them via APM it is very slow, but when i bypass it is fast. I tried using http watch and found that some of the pages are getting response of 404. But that is not the case when i am bypassing the APM.
I assume that the Rewrite profile is taking a long time to rewrite the content. Is there any way i can troubleshoot the issue.
I have one Virtual Server with 8 portal access configured on it. some of the applications which are running on port 80 in the back end is working fine. while the portal running on port 443 shows a huge delay.
Vs 443 offloading --> Portal Access 80 good performance.
Vs 443 offloading --> Portal Access 443 too slow.
BIG-IP version 11.6.0 HF4
Thanks.
Debugging rewrite profile issues can be really tricky and time-consuming.
This article and the associated tool is the best. Have fun !!
I recommend a tcp/ssldump along with the below trace for a full picture of what is happening.
cheers.
Hi
i have the same issue - Did you find a solution to the issue ?
Eyal
