I’m trying to create a Portal Access List with a few web resources, and one of the links does not work because it is an Apache server that is validating that the SNI and HTTP hostname match. The problem is, that when the user logs into APM and launches the web link, they are launching a request to the APM and not the backend server… therefore the SNI is for APM and does not match the HTTP hostname in the header (which is specified in the Portal Access link via Application URI).
[ssl:error] [pid 11111] AH02032: Hostname xxx.yyy.com provided via SNI and hostname aaa.bbb.com provided via HTTP are different
From what I’ve read, this cannot be disabled on the Apache server without removing SNI and recompiling… which is not an option for me. However this F5 use-case seems like it would be fairly common, so I’m not sure what I’m missing here.
Anybody have any thoughts?
Thanks-
