Hello Devs!
I’m trying to design a policy that a client would auto connect to the VPN and the webtop, with the internal apps links, did not have the VPN link. Let me show an image:
I was able to configure the auto-connect part, but the “Corporate VPN” link is still showing on the webtop. I wish it was gone/hidden.
My policy is as follows:
This policy is type SSL-VPN. I tested as type “All” and with this configuration:
The configuration inside the “landing page” is as follows:
Any thoughts? I just want to auto-connect on the VPN and show only the “Portal Green” icon. Corporate VPN should be hidden (or not even there).
Thanks! Rafael
Hi Rafael,
You can use the APM Advanced Customization to make the ‘/Common/vpn-network-resource’ button on your website to be hidden. To achieve this add the following javascript code to the footer.inc file of your access policy.
I’ve tested this code with version 14.1.0.3.
<script>
if (window.location.href.indexOf('vdesk/webtop.eui?webtop') > 0 ) {
document.getElementById("webtop_favorites_inner_container2").style.display = "none";
document.addEventListener('readystatechange', event => {
const sleep = (milliseconds) => {
return new Promise(resolve => setTimeout(resolve, milliseconds))
if (event.target.readyState === "interactive") { //same as: document.addEventListener("DOMContentLoaded"... // same as jQuery.ready
//alert("All HTML DOM elements are accessible");
if (event.target.readyState === "complete") {
//alert("Now external resources are loaded too, like css,src etc... ");
sleep(500).then(() => {
document.getElementById('/Common/vpn-network-resource').style.display = 'none';
document.getElementById("webtop_favorites_inner_container2").style.display = "block";
</script>
