APM OnDemandCertAuth on custom tcp port
I have created a basic VPE in order to check the SSL client certificate (ondemandcertauth set to request) that is linked to a virtual server with custom client SSL profile where authentication is setted to IGNORE. Everything works fine but when I change the virtual server’s listenning port(different from 443), a redirect to the host (without preserving the virtual server port) occurs leading to a connection close (no virtual server is listenning on port 443).
Thanks Emmanuel
It looks like you might have identified a bug. I would suggest opening a support case on this issue.
-Seth
