APM - NTLM client authentication
What we are trying to do is have the clients use NTLM auth when they authenticate to the F5’s so that when they connect using a supported browser the authentication is passed through.
The second part is, using those credentials to then pass on to other systems which will potentially use forms based authentication (potential killer i know)
We are using Version 11 F5’s in a HA pair, and i’m open for any suggestions :slight_smile:
Cheers
Hi Andrew,
APM will support clientside NTLM auth in the upcoming 11.3 release. You can talk with your F5 or partner SE to get details.
Aaron
