APM - MDM Compliance with Airwatch Fails with New F5 Access for iOS 2018 Client 3.0
The updated 3.0 version of the iOS client from the 2.1.1 version has broken the MDM query to Airwatch just as the document discussed it would with the absence of the UDID.
myF5
Is there a work around in place to force compliance even in the absence of a UDID in the 3.0 version or will it be resolved in firmware or elsewhere before the 2.1.1 version is deprecated?
I suppose we have a certificate common name on the iOS client device that matches the UDID assigned from Airwatch. Could I get fancy and variable assign the two missing UDID variables the value from the certificate common name?
session.client.mdm_device_unique_id - Assign value from certificate common name session.client.unique_id - Assign value from certificate common name
Could I then pass the above variables to the Airwatch system for a successful MDM compliance query?
