Hello all, We’re using OCSP responder in an APM policy after a Machine Cert Auth. The “session.check_machinecert.last.cert.issuer.cert” variable is not populated by the Machinne Cert Auth. So we have to assign the variable with the cert issuer value … That’s working, for sure, but : - when the CA cert change we have to change it in each oh the APM branchs - We have two differents CA authorities, so to separage assign with the different values, etc …
No way to make it easier ? Have a good day
you can create at the beginning of the VPE one variable:
session.custom.issuer.cert
with the CA cert.
Then after Machine Cert box, create a variable assign with
session.check_machinecert.last.cert.issuer.cert == Variable session.custom.issuer.cert
when the CA changes, change only the first value.
Salut à tous,
Stanislas gave me a first tip but my problem is more complex, let me explain more : - I have to check computer certs in multiple access profiles - In each of them I must check that the cert issuer is from CA1 or CA2 … - I also have to save the CA cert issuer for the OCSP check … As you may see in the attached screenshot it’s getting not easy to manage and really bad optimization.
Bonne journèe
