APM Logout URL trying to logon again using the same browser session
I am running into a problem with an APM Logout URL and SecurID. When I have a user log out of the application the Logout URI configuration removes the session. This is expected and working fine.
The issue I am having is that when the user tries to login again within the same browsing session, a new APM session is created and the user gets an error during login authentication. As far as I can tell in SecurID the error is that the password provided is regarded as null.
Is this expected behavior with Logout URL?
Do your users wind up at the URI /my.logout.php3, and then click the link to start a new session?
By the way, what version are you running?
Thanks, Josh
Do you use an external logon page? If you can provide any configuration examples, it may help.
No, we use the standard logon page. I will try to get something on the next working day.
