APM Login page custom Error description, for AD and Radius
APM login using two-factor authentication. I have set up AD and Radius (Digipass Vasco). All login failures show incorrect username or password. How do I customize, to show a token failure versus a AD failure for the login page?
Variable assign shows the following.
session.custom.holder = expr { [mcget {session.logon.last.password}] } session.logon.last.password = expr { [mcget {session.logon.last.token}] }
quite a while ago, but i had it open somewhere so why not provide the answer
you want to look at the customization section, choose general and then go to the Text tab instead of Branding
go to Access Profiles > /Common/<your-profile> > Error Messages > AAA Errors
there you can modify a lot of the error texts
