APM Linux EDGE Client File Checker
hi,
i am using the command line (f5fpc) to connect to the APM.
my policy has a file check policy object.
the file check does not seem to be working, tried using the logging object to print the file check session variables but they are empty.
any ideas?
thanks.
Just in case anyone else stumbles across this question, the answer is:
Access Policy Manager® (APM®) supports two Linux clients, a CLI and Network Access client components that support web-based access. On the CLI for Linux, APM supports logon with user name and password only and does not support any endpoint security features.
