I am testing APM Configurations and i cannot get passed this message. What could be the problem? I have verified that the lic I am using on my LAB VE is up to date. I am running 11.5 currently. Any Input on this would be greatly appreciated.
Your session could not be established. Invalid Session ID. Your session may have expired. Thank you for using BIG-IP. To open a new session, please click here.
whelp for right now i have just one session, which is my own. the only thing I have really tested is using a basic ACL with 3 entries in it.
Just for giggles, can you build a second simpler access policy with a message box:
start -> message box -> allow
Apply that policy to your VIP and test. If you see the message box and get to the application, then it’s a safe bet there’s something wrong with the other policy. If you don’t see the message box, then we should look at APM as a whole.
I Have tried that Setup and created a new policy and i still get that error. I went back through the configuration of setting the access profile up and applying it to the VIP. and I noticed that I do not have a connectivity profile selected under the access policy section in the vip configuration pane. i am going to look at setting up a basic one.
You wouldn’t need a connectivity profile for the simple start->message box->allow policy. It should basically be this policy, an HTTP profile, and a pool assigned to the VIP. Does that still fail? The title of your thread suggests your in APM limited (lite) mode. Is that correct?
Right I purchased the 98$ VE lab Edtion and am experimenting with APM. Theoretically I shouldnt have any problem because it is just me creating sessions. unless there is some further restriction on it,
I have not been able to make any progress on this. I think its a problem with the F5 not detecting new sessions. But im not sure.
I actually made a bit of progress on this, I Have been able to successfully get a somple APM profile to work correctly for an https VIP, I still how ever cannot insert any URIs on the VIP, I get an error that tells me that the BIG-IP cannot find connection information in the request from the client.
I have the exact same issue - how did you fix it?
So, from reading this i can see two possible issues. In the cookie section of the APM configuration (where it mentions SSO domains), there is a checkbox called “Secure”, if thats ticked, APM won’t work without HTTPS and a cert. The other thing is, i’ve noticed with our APM setup, that occasionally, APM just breaks and won’t allow us to start a new session (same error that you mentioned), and the way we got around that was by closing all instances of the browser and re-opening it. We have only ever seen that message when we have been testing things, never on a production instance.
please start a new question Cameron Fairbairn 2 if the above reponses dont help you. would be wiser to restart trouble shooting with you. then do it here.
Sorry didnt have a chance to get to this. The Solution i discovered was my VIP was running on port 443 and for what ever reason it did not like that. I played with the ssl profiles and creating cert key pairs etc…but to no avail. My resolution really was to move to port 80 and then just encrypt on the back end where i had resources that needed ssl(I was trying to do ssl passthrough with APM). Hope this helps!
