apm landing uri - bookmark issue for lambda users
This issue was always there with the Firepass (sol11580)… continuing with APM.
I have APM (portal mode) services that are accessed with landing URIs (https://abc.example.com/service1 ; https://abc.example.com/service2). Working fine. Now, when users want to bookmark that, it’s not possible (except manually creating the bookmark) because of the redirect to https://abc.example.com/my.policy
Anyone has a workaround for that (and knows the RFE maybe)?
Thank you
Alex
We had accomplished this when we used an external login page with some iRules that would add the initial URI to the query string as a parameter, and then if the user went to the page with a GET (instead of a POST, as the APM redirect would do), it would redirect to that uri (e.g. /service1), which our other iRule would grab that as the start uri.
In my attempt to rework the way we’re using APM, I’m working on something similar for the built-in login page. In an iRule, you can use the
HTTP_RESPONSE_RELEASE
event to check for the redirect to /my.policy and update the uri from there so they could bookmark that page. So in the
ACCESS_SESSION_STARTED
event, you could set a custom session variable for the start uri (i.e. session.custom.starturi),and then update the uri to include that on the login page.
when HTTP_RESPONSE_RELEASE {
    switch [HTTP::status] {
        301 -
        302 {
            switch -glob [HTTP::header value Location] {
                "/my.policy" {
                    switch [ACCESS::session data get session.custom.starturi] {
                        default {
                            HTTP::header replace Location "[HTTP::header value Location]?r=[URI::encode [ACCESS::session data get session.custom.starturi]]"
After that, you’ll need to make sure the
event handler also handle uris with my.policy in them..
when ACCESS_SESSION_STARTED {
    switch -glob [HTTP::uri] {
        "/?r=*" {
             If we have an empty path and an "r" parameter, we'll use that as the starturi
               The "r" param SHOULD be uri encoded
            set starturi [URI::decode [URI::query [HTTP::uri] "r"]]
            if { $starturi starts_with "/my.policy?r=" } {
                set starturi [URI::decode [string range $starturi 13 end]]
        default {
            set starturi [HTTP::uri]
    ACCESS::session data set session.custom.starturi $starturi
Then your iRule for handling starturis can deal with the redirect after the user is authenticated.
Hope this helps…
