Is it possible to create and irule event to check “session.client.serial_number” against an API dump which must be downloaded on the fly from and url, and check “session.client.serial_number” against the value of a “serialnumber”
Any ideas on how to get about it please?
Regards, Etienne
You can create a HTTP auth to request API.
if you have to manage in irule the response, you can create an virtual server to convert request / response from API to be managed in APM AAA HTTP Auth server.
Access Policy --> HTTP auth --> virtual server with irule --> API server as pool
the irule will insert in cookie / header information you can retrieve in variables.
I wrote this irule applied to a virtual server API converter for air watch.
set AWuser [URI::decode [URI::query [HTTP::uri] AWuser]]
set AWpwd [URI::decode [URI::query [HTTP::uri] AWpwd]]
set AwTenantCode [URI::decode [URI::query [HTTP::uri] AwTenantCode]]
set b64auth [b64encode "$AWuser:$AWpwd"]
HTTP::uri [HTTP::path][URI::query [HTTP::uri] uid]
HTTP::header insert "aw-tenant-code" $AwTenantCode
HTTP::header insert "Content-Type" "application/json"
HTTP::header insert "Authorization" "Basic $b64auth"
unset AWuser
unset AWpwd
unset b64auth
unset AwTenantCode
when HTTP_RESPONSE {
Trigger collection for up to 1MB of data
if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576}{
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
Check if $content_length is not set to 0
if { ([HTTP::status] == 200) && ($content_length > 0)} {
HTTP::collect $content_length
when HTTP_RESPONSE_DATA {
do stuff with the payload
set payload [HTTP::payload]
foreach str {UserName Platform} {
set strlengh [string length $str ]
set fieldstart [expr {[string first "\"$str\":\"" $payload] +$strlengh +4}]
set fieldEnd [expr {[string first "\"," $payload $fieldstart] -1}]
set field [string range $payload $fieldstart $fieldEnd]
HTTP::header insert $str $field
HTTP::cookie insert name $str value $field
