APM, How to query custom header before routing to Logon Portal
Hi All
I am new to APM and setting up a POC to present a logon page, I have been able to set up a basic Access Policy but need to now look at only presenting the logon page to external users and not internal users.
I know this possible with a branch rule however the site is hosted via a CDN so internal users also present themselves via an external ip, a custom header is inserted by the CDN which captures the client ip in a custom header.
I am want to query the custom header and if matches a known ip address don’t present the logon.Being new to APM I have had a read through the forums and not tracked down the best way to approach this.
Any suggestions would be welcome
you can use following irule to create a session variable with IP address in header:
when ACCESS_SESSION_STARTED {
    ACCESS::session data set session.custom.CDN_client_IP [HTTP::header "X-Forwarded-For"]
then, create a branch rule filtering on this variable
if you want to disable APM when client IP is internal, you can use following code
    if {[IP::addr [HTTP::header "X-Forwarded-For"] equals "1.1.1.0/24"]} {
        APM::disable
ACCESS::disable is only working in LTM+APM mode!
Yes, you can configure the branch with advanced expression.
You can configure the expression in first tab then change variable name in second tab!
Thanks for your help, I have managed to get it working using the branch filter.
Thanks again
