Hello All,
I build a policy that depending of the hostname requested by the client, a client certificate is require or not.
This is the view of my policy :
The two boxes “Hostname 2 ways” and “Hostname 1 way” are empty box. Within the box the following expression :
“Hostname 2 ways” : Expression: expr { [mcget {session.network.name}] contains “foo” and contains “test.com”}
“Hostname 1 way” : Expression: expr { [mcget {session.network.name}] contains “bar” and contains “test.com”}
During the test, i have an error message saying that the session couldn’t be established.
On the APM report i have the following information :
Access policy result: Logon_Deny
Rule evaluation failed with error: syntax error in expression " [mcget {session.network.name}] cont
Is someone have an idea of what i’m doing wrong ?
Thank you for your help
expr { [mcget {session.network.name}] contains "foo" and contains "test.com"}
is not a good expression
expr { ([mcget {session.network.name}] contains "foo") && ([mcget {session.network.name}] contains "test.com")}
if the domain is test.com, it’s better to use
ends_with
instead of
contains
Why do you create 2 boxes for hostname check? you can create a second branch in the first box?
Hello Stanislas,
Thank you for your reply
I don’t have the error message anymore, but it’s still not working as i wish, so i will follow your advice about using only one box for hostname check to simplify the policy.
Hi Stanislas,
For the expression
expr { [mcget {session.client.hostname}] contains “HTPA387” }
If i want to allow multiple hostnames, which adding additional branches are not efficient, how can i just add the list of hostnames?
If you want to add add list of hostname, you can do this:
expr { [mcget {session.client.hostname}] contains “HTPA387” || [mcget {session.client.hostname}] contains “hostname2” || [mcget {session.client.hostname}] contains “hostname3” }
Regards
