I am running APM V11.2. I can see the logon page with front image in full browser i.e. laptop, but when I use ipad or iphone I do not see the front image. Can anybody help how to enable the front image visible if I use safari on iphone.
You can do this in the Access Poilcy → Customization section…
- Go to “Advanced Customization” view
- Under Branding expand “Access Profiles” → “your profile name” → “Common” → “Page Header Settings”… in this section you will see “Header left image (Full Size)” and “Header left image (Mobile Device size)”… you will need to upload your image and set it under those settings… save… apply policy and you should now see your logo on both formats.
Please let me know if this doesn’t work for you or if you are having a different issue.
Seth
Hi Seth
I can see the header left image but caanot see the front image. I can see both front and left image via normal browser but if I use mobile browser then I can only see the left image
Pramod
