APM Guided configuration is missing from my BigIP trial VE.
Any idea what can be the problem?
Hello Ricardo.
What do mean by missing?
Trail versions have options for guided config, but maybe you are facing some kind of bug. Check this out:
Regards,
Dario.
It’s really missing.
Not showing here, on the gui, anywhere.
What release are you running?
Take into account that guided config is not available in all releases.
Regards,
Dario.
I’m running v16. But v15 also does not show the APM guided config.
Hello Ricardo.
Check this out.
Regards,
Dario.
Ok.
That explains it.
Thanks.
Hello Ricardo.
Please, don’t forget to mark my answer as ‘the best’ to help other people to find it ;-).
Regards,
Dario.
