APM Full WebTop resource grouping and sorting
Hello,
Is there any good way of grouping and sorting resources in the full WebTop now? I see some olders posts referring to FID447568, but I cannot see any good options to group resources.
Ideally, I would like the option to add folders and assign resources to folders. Sorting could for instance happen based on the Caption.
-BR
Yes F5 provide a smart way to do it using “Webtop Sections”
Go to “Access ›› Webtops : Webtop Sections”
So you can create several section and add it all ressource that you want (it will permit you to group an sort)
Then create different sections ex:
  • RDP sections: all rdp you want.
  • AP section: all portal access.
Then assign this webtop in VPN in advanced ressource assign.
For more info: Webtop Sections
keep me update if you need more details.
regards
