APM Edge Client Timeout Values
Hi
is there any way to notify users when their session is about to end and give them an option to extend when using the Edge client? Also, is it possible to set different timeout values for different groups of users or is this the same across the whole APM policy?
Hello, they should is a pop-up notification just above the system tray when they are about to hit the timeout. To use different timeouts you could add and AD Query for the groups and then on each branch use a variable assign to set the “session.inactivity_timeout” session variable.
