Hello All,
Is there a way on the APM policy to verify the client certificate via an HTTP CRLDP that is not based on the information from the client certificate but manually defined ?
Thank you for help
Hello All,
Thank you for help
In short, no. When you select “No Server” as the Server Connection option in the CRLDP AAA, it’ll follow the HTTP CRLDP URL in the client certificate. The other Server Connection options are for LDAP-based CRLDPs. If you’re willing to host the CRLs locally (on some local web server), you could force the real URLs to resolve locally with Hosts entries. Otherwise you’d have to try to rewrite the CRLDP field in the X509 before it got to this agent. It is definitely possible but not trivial.
Hello Kevin,
Thank you for your answer.
