Hello,
I’m configuring APM CRLDP for HTTP CRL retrieval and have a few questions about it. When you select pool or direct the base DN field must be populated. Does this mean that HTTP method is not applicable when you enter a destination IP? i.e. you cannot manually define CRL destinations and must use the ones contained in the client cert. If this is correct how does the APM handle multiple CRL destination URLs in the certs, timeouts and such?
thankyou
Hello,
When you specify a destination, it’s for ldap only. In latest versions you have a third option. When checked APM will look in the crldp field of your certificate
Hello,
Of course, if the crldp field in your cert is invalid or non existent. You have a problem. To workaround this, you can define a crl in the clientssl profile and update it using cron and tmsh
if I understand - for HTTP CRL you must use cert CRL field when using CRLDP
You should use an CRLDP AAA object and select the option No Server. This way, the bigip APM will use the crldp field in the client certificate. You have to add a CRLDP block in your VPE
If there is no crldp fields in the client cert, you can configure the Certificate Revocation List option in the Client Authentication settings within your clientssl profile. No need to add a CRLDP block in you VPE, a Client Certificate Inspection is enough
And to update your crl, you can use a cron job in cli. Here the tmsh command to update your crl : modify sys file ssl-crl mycrl.file source-path http://mycrldpuri/MyCA.crl
thank you for the helpful information
