APM + Cisco ISE and Dynamic ACL
Hi there,
I’m trying to assign user based ACLs downloaded from Cisco ISE everytime a user logs in however I get the error “ERR_PARSER_UNSUPPORTED_TOKEN” and it is not working. I followed the F5 guidelines here. I tried a simple scenario with a single entry ACL but still not works.
How can be this implemented? Thanks.
Certainly a problem with the format of the ACL retrieved from your CISCO ISE, F5 is unable to parse it.
Can you give the content of the session variable that contain the ACL?
